I’m trying to set up the Sudsy Plugin. I can get it to work on the test pages so the link looks thus: allumagain but when I send the page to live mode the page has a double slash after the domain name eg: allumagain
If you can show a screenshot of the expression you’re using for the URL, that would be helpful; but the first thing that comes to mind is that the built-in Website home URL data source already includes a trailing slash, so you needn’t add one.
If you’d like additional help, please DM me a link to a view-only version of your editor.
These are the 2 links I’m using. They work fine on the test website but when the site goes live I get https://jobbydealer.com//glamour-model/Poppy%20Coles the problem with the link is // appears twice rather than once.
A Bubble page name can be anything (including a single character), but the plugin must be used on internal pages. If that doesn’t fit your use case, the only solution that comes to mind is a proxy service such as CoAlias. (I can’t provide support in that scenario, but there’s a chance you might not even need the plug-in in that case.)
