Sum with split, is possible?
I don’t know if I’m doing it the right way, but the :sum doesn’t appear, I know I can create an individual table for each K/D/A, but if it’s possible to perform this operation using only one field, I’d be happy :slight_smile: any tips? or resolution to get this result? KDA = 5/10/15
list of KDS: [Format as Text (see below)]:split by ^, each item convert to number : sum
inside this KDA ( this KDS split by (/) , each item convert number : sum
seperator = ^
