Tagger and Repeating Group whit Ext Vertical Scrolling, how to call a workflow
Hello,
I’m building a blog app, in the comments we can @ other users since i’m using the Tagger Plugin.
I use repeating group whit ext vert scrolling to do a facebook like, the problem is that the tagger plugin is set when the page load so it works for the first posts but as i use the ext vertical scroll, posts are loading after a scroll that’s why the tagger doesn’t work on them.
So how to create an event that launches a workflow (for @) as soon as a post is loaded in ext vert scorlling ?
Thanks
