TinderPile Info showing mismatch info
Hi there,
Hope you guys can help. The green workflow contains a pop up sequence if the match is mutual and shows the tinderpile’s real name and profile pic.
It has been working fine until I added the testing account workflow. Now the match popup is either empty for the test account, or contains another user’s info when matched, which is a big nono.
Do you guys have any idea as to how to fix this?
Thanks!!
