Toolit Kit ForEach starts only if there is a breakpoint for debug mode
Hi everyone,
I am using Toolit Kit ForEach function to create a thing on every iterated item (20 records).
So, when I check ‘Add a break Point in Debug mode’ in ‘Start For Each ForEach A’ workflow and run the app after it stops at breakpoint - everything works and a number of iterated items is correct. Without this breakpoint, the status of this ForEach is ‘Ready’ though iterated items number is 0. Basically it doesn’t start.
Any ideas?
Hey @cxdk
Unfortunately the breakpoint will cause a the plugin to show inconclusive results. I am afraid that this is common behaviour across similar plugins we tested so it is not confined to this particular plugin.
Ali Farahat
Co-Founder
TheUpstarters.com
