Turn 0.8 into 1, without using :ceiling
Hi, the result of a division equals 0.8. I need it to to turn into 1, without using :ceiling.
Is there a way to set up the minimum result for this calculation to be always 1? (this is what I need, to setup a minimum for the result)
Is this function my solution? … ← min → …
How do I use this function?
Any help will be very appreciated. Thanks!
Hi there, @pachocastillosr… I am probably missing something here, but couldn’t you use a condition that says when the result of the calculation is less than 1, set the value to 1?
Best…
Mike
Hi Mike! No, I can´t do that because the formula is in a dynamic text (see the cursor in the picture), I am not using workflows for the calculation.
Why don’t do this calculation and validation in your workflow? I don’t see any reason…
I just wanted to know if it was possible without doing that, to keep it more simple
