Urgent Help Workflow Stops for No Reason
I am totally stuck out of nowhere there is an issue… Why would a workflow just utterly stop and freeze for no reason, then after 5 min spit out an APP TOO BUSY error?
Can you show the result of the “Only If” statement here
well i have discovered that turning off commnuity plugins fixes it… but that is not a solution :frowning:
Probably an issue with the plugin itself. Which one was it?
here is the issue… there are no plugins being used in that workflow other then stripe which is a bubble plugin and not a community one
