Using alot WU in a circle to load files
hi bubblers..
so i have this issue that i cant seems to fix..
when i open a task window to see more data about a created task i am suppose to see eventually added files and documentation for this task.. (displayed under the text: “opgave filer”
but when i load the page the files is just blinking and having issue in loading and get displayed.. i see this use alot of WU because it keeps going in circle to try load these files..
can anyone maybe help me sort this out?
Best Regards
Christian Bargmann
show screen shots of the search used to populate the files and the data structure of database and the structure of the container element that shows all the details (ie: the screen shot you did provide)
Hi @boston85719
I cant provide screenshots from where i am right now.. but i can try explain what you are asking..
My db structure is set up as a task with a field called “added files” there is a type list of files..
So in a create a thing workflow it uploads the file and added it to the list of added files..
When i search for it in a RG er search for current page task and ever container and groups have that data source..
I have a workflow that when i click on the file it will show a popup where it will preview the file in.. that works with no problems.. it is only when it gets displayed in the RG that it have struggle to get displayed correctly and with not blinking
Test it first in an isolated environment or on page directly (not in popup) and see if it happens there or not as your source should just be ‘current page taks files’ and the type of the RG can be files or just text, and I’d say text simply because all you need is the URL of the file, so if you use text, your source will be ‘current page tasks files urls’…unless you are trying to show the file contents from within the RG which is not recommended.
Oh no then you misunderstood.. the popup is only to display current cells files url as a preview.. but the RG is on the page where i want to display a little miniature of the file
The miniature of file is likely source of problem, just show something user clicks and open file in new browser tab
here are a video of what is happening and that i cant figure how to make it stop doing.. i have this setup multiple places in my application with no issues.. its only here it does it
Thanks for sharing the video. Would you please show a screenshot of your RG whenever you can ?
hi @ahmed.elkaffas
ofcourse
Great ! Please use a “RepeatingGroup” instead of a “Table”
that didnt work.. same issue but worse.. so i shifted back to a table
Remove the preview file plugin element.
no… i want the preview of the file there as a miniature.. im asking how to not make it blink like as it shows in the clip above
could be the plugin, so contact the developer, or could be the height of the RG, I’m not sure, I’ve never used that plugin, but plugins do cause WU issues in Bubble all the time now, especially when used in a repeating group or table element, and since you are seeing high WUs because of the repeated loading, it is likely to do with the plugin itself.
but im using this type of setup multiple places on my application with no issue at all.. i can try work with the height of the repeating group to see if that will do any different :slight_smile:
Check them, there is likely a difference, one of which I imagine is that maybe the plugin is not used in a repeating group or a table or the repeating group or table are not in a popup
yeah they are all used in repeating groups.. but im not using them in popups as i also say further up.. the popup is only used when they click the miniaure picture to display current cell’s the file in bigger view
if they are working in other places and are the same setup, just copy and paste it into the place you want it
that was what i did when i maked this one.. thats why i dont understand why it does this
