Thanks for that, I’ve tried it but Intercom doesn’t seem to like it, however when I add the current date manually from Unix Time Stamp - Epoch Converter it does work.
Workflow error - The service Intercom - Event just returned an error (HTTP 400). Please consult their documentation to ensure your call is setup properly. Raw error: {"status":400,"error":"There was a problem in the JSON you submitted [f8b9b18ddd76eb58b63aef368e37228f]: not a number (created_at) at line 3, column 18 [parse.c:435] in '{\n "event_name" : "intercom-test",\n "created_at": 01012019,\n "email": "james@gofelix.ai"\n}"}
Since November, the API Connector can handle Unix date @allenyang would it be possible to implement this please ? Many API requires UNIX timestamp and we must use third party plugins to generate each date field.
Maybe using the date : formatted as (UNIX) ?
It was already a request back in the very early days, April 2015 : Dates in UNIX format
