Vertical offset for "scroll to entry"
Currently, when scrolling to an entry in a repeating group, you’re not afforded the “offset” option (which is available in the “scroll to” action for regular elements). This sometimes results in elements in a RG cell’s elements being hidden behind the header when they are scrolled to.
To prevent this, is it possible to get the “offset” option applied to the “scroll to entry” action?
