I logged in to work on my app this morning and am having some problems. I have seen the announcement about the database, and it could be to do with that, but I don’t really see how.
My app was working fine until this morning, but now when I try to go to a version-test page, it redirects me to the version-test/reset_pw page, or the version-test/candidate_dashboard/reset_pw link (which will be a reset password popup I have. This is after simply typing hirely.com.au/version-test/candidate_dashboard, or pressing preview from the editor.
And sometimes shows the page below instead.
I have deleted all bubble and hirely cookies. Can anyone shed some light? I was hoping to get a lot done on this today.
www.hirely.com.au/version-test/old_index_1 - redirects to hirely.com.au/version-test/reset_pw
www.hirely.com.au/version-test/candidate_dashboard - shows the page I pasted before saying redirected too many times, or redirects to the reset_pw page
I have added a temporary button (edit me) to the reset_pw page which shows login popup, but even after logging in (and proceeding to dashboard) it should go to the candidate_dashboard page, but instead shows the redirecting too many times page
I imagine there are more, but these are the ones I have found this morning thus far.
Also, is it possible to get this sorted quickly? I was hoping to release a live updated version today, but can’t do too much whilst this is happening as I have a fair bit of testing to do.
I have submitted the bug report, including the log in details, but I don’t think they will help given that the bug means there is no issue to log in - as it redirects to the reset_pw page.
However, you can click on a temporary button on the reset_pw page (just says edit me), and use the log in details there - but then still doesn’t work.
Has always worked properly until this morning’s first test.
