Which is better... using svg as icons or using plugins for you icons
Which is better… using svg as icons or using plugins for you icons
Depends on how the plug-in is made. I’d assume that most icon plugins use SVGs. If the plug-in uses SVGs, then it’s the same.
Thanks… that puts my mind to rest
