Why does my footer and header not drag onto new pages in their right format?
Hi, I made a header and footer as reusable elements. I drop them onto new pages but i have a few issues.
  1. when i drag them they don’t scroll out into their rightful dimensions they do this (pic attached)
  2. How do I make them “stick” and stay to the bottom and top of a page while I build in the middle of the page? they keep moving. Also if there’s suggestions about how big to make a page while I work on it that’s appreciated.
Thanks you
Hello
Try to change the layout of your page as column
Put a group between you footer and header. No fixed width or height
Set a fix height for header and footer but no fixed width
@bp89 :wave:
As an alternative. Convert the group into a floating group and stick it to the top left and let it stretch across the page. :blush:
This worked! Thanks Sarah :slight_smile: …Do you know how I can lock my newsletter module to the right side of my footer? the footer is set as a row and i made a group for the newsletter module and made that a column so i could design the form…
Yes you should group your four left columns together.
Then set the parent container group to space between, and the email column will go right.
Did you watch bubble design courses from @gregoryjohn ? https://youtube.com/playlist?list=PLoNVJrdvQQYnt7KVJ1VFWPzcHLUkZ0cVP&si=EdO5PFn5QuHcb_Z9
