Work Flow issue when using If
I need help debugging a Work Flow issue.
I have 3 inputs
A B C
The value of input B changes the value of input C
So if B = 1 ; C = .1
So if B = 2 ; C = .3
So if B = 3; C = .6
I need to save the result of C and then perform math using that result.
Work Flow
When Input B Changes
Save A
Save B
→ If B = 1 Change C; Save C
→ If B = 2 Change C; Save C
→ If B = 3 Change C; Save C
Math (B*C) Save result
If I go in order, 1, 2, 3 everything is good. After I go to three and go back to 1, the B=3 is saved and it won’t switch.
Any thoughts on a better way to do this?
Hi there, @timlcooley… I could be way off base here, but do you need C at all, and would it simplify things to remove it from the mix? I mean, if you have a field where you are saving the result of the mathematical operation, then it seems like that field’s value would be B * .1 only when B = 1, B * .3 only when B = 2, and B * .6 only when B = 3.
So, I guess I am envisioning a workflow that saves A and B in step one, and then there are three conditional steps (the ones I mentioned above) that save the result.
Any of that make any sense and do you think it could work?
If I am off base, maybe post some screenshots of your current setup because it’s kind of hard to follow what you mean by…
Best…
Mike
Here you go! The issue maybe with the “results from…”
Save A
Save B
I could still be off base here, but if I am seeing things correctly, I don’t think the thing to change in the last screen shot should be the result of step 4 because step 4 (assuming the screenshots are the steps) isn’t always going to run. Are you using the result of step 4 in that step to try to enforce the order of the workflow steps?
Yeah I just want to make i get the numbers I need. I had issues in the past where I needed the number from a previous workflow and it would break the end result or not work at all, so I figured if I forced it to calculate I would be ok.
Hmm I removed the Forced “Results of Step 4” and it worked… haha :slight_smile: Thanks for the chat.
