Work Flow Problem
Hello,
So I am currently working on my admin panel for my CAD/MDT for my gta rp. I was just wondering how u could change in the ‘change another field’ area from an = to remove, if this makes any sense.
55%20PM
Thanks.
What are you trying to remove? Are you trying to remove the user from the department? Or the department from the user?
The way you’d go about this depends on how you have your database set up.
I’m trying to make it look like this, sorry its a little blurry.
IMG_0523
I am trying to remove the department from the user.
In the blurry screenshot, it looks like Approved Departments is a list of things, but in your screenshot, it looks like it’s just a single thing.
So how do I change it?
Have you done the bubble tutorials yet? Those describe the basics of how to set up the database
