Hi
Bubble work load increase alot and i do not know why it increase so much. I do not have back end work flow only normal search function but every month the WU blown. we only have 1595 data …
Anyone having this problem
Hi
Hey! Even with a small dataset, WU can blow up if repeating groups or elements do lots of searches, or if auto-binding/input actions run frequently. Check page load workflows, RGs, and plugins, these often add hidden usage. Optimizing searches and limiting automatic updates usually helps a lot.
i only do one search … no page load function.
Thank for your help i think i write a bug report to them to investigate.
Check your WU usage charts. Drill down, find out what is using the WU
this is super interesting let me show you
The overview
Deeper
Base on hr i see there is no work load so i think it is a bug…
You can click on the pie chart, and keep seeing what is spending the most WU:
Until you get exactly to the place itself that is consuming the most:
yap i check even if there is not one using still spike up. it is crazy i think they are checking. crazy bug. also there are zero backend work flow and recurring work flow
Are you saying your pie chart (as sampled above) shows no WU usage?
This is also interesting
1 day work load. no back end work flow no recurring. 160k WU per day with only 1 user.
Pretty sure the issue is on your side/design/settings of search. 17 254 searches by only one user in one day? Click on Search for leads to see more…
Are you doing a search for leads inside a repeating that searches products or some other ‘nested’ repeating group that nests a search for leads into another RG?
not nested at all anyway now bubble team check for me. Thanks
Is the search a WF action or a data source? It could be a bug but I’m asking cause I’m curious.
