i have two buttons can it should possible when i click on first button then second button automaticaly clicked
Hi there, @amandeep.brisklogic… it’s not clear what “automatically clicked” means, but you can easily run the second button’s workflow when the first button is clicked by simply including the same actions in the first button’s workflow.
If my reply doesn’t help, consider sharing a lot more information (including screenshots) about what you are actually trying to do.
Best…
Mike
i have two button lets say button submit and button save if i click on button submit then the workflow of both the button should be run
Okay, then like I said, include the workflow actions for button save in the workflow for button submit, and you should be good to go.
Okay, will try this
Thanks BTW
