This should be widely applicable. I’m trying to build Scrabble, and this step involves:
- Placing the tile on the board (which is just a repeating group of tiles)
- Removing that same tile from my hand
The issue is, the workflow doesn’t execute sequentially so sometimes the tile is removed from my hand before being placed on the board. I can’t use a separate workflow condition for “Do when…” because this is for a group inside a repeating group.
Any ideas as to how I can force this sequential workflow? I also tried “Use result of step 1” to no avail.
Here’s step 1:
Step 2:
Really appreciate any help!
Hi there, @ch.kr.lee… just a thought, but could you do the second step in a backend workflow and schedule that workflow to run at the current date/time plus a few seconds?
Best…
Mike
And if you try to store the valeu in a “state” and after this, remove the object from your database based in the stored variable?
Complementing @mikeloc suggestion, if you need to run it on the page you could also create a custom event and schedule it a few seconds later.
Did that! Still not working, which leads me to believe I may actually have a different problem than workflow ordering (potentially the way i structured my database is just wrong).
Thanks for the help anyways, will keep digging and update this question once I get to the bottom of it.
