"Yes" "No" Element
Is there anyway to make the Yes and No Element Capitalized when selecting it?
Hi ParliamentJohn,
could I ask what is your use-case?
Note if you are displaying a yes/no you can use: formatted as text & capitalized.
2019-11-10%2015_08_18-Todolisttool%20_%20Bubble%20Editor
In a similar way you can create a new field type text (below the username) that is the yes/no field (here “admin”) but formatted as text and capitalized.
2019-11-10%2015_12_41-Todolisttool%20_%20Bubble%20Editor
If you want Yes/No and yes/no this is overall 4 pieces of info (yes or no & capitalized or not capitalised so a field type number may be better suited.
hope this helps
pm me if you need further help
happy bubbling
Julius
Co-founder of TipLister. Pinterest for step by step advice. Add your Bubble tip on https://www.tiplister.com/
