Zerocode Pipedrive Plugin Help
Hi people, anyone had any success using the ZeroCode PipeDrive plugin?
I want to use Bubble to capture deal/contacts and create new ones in to Pipedrive.
I have added my personal access API keys and now in a workflow I will assume it works like this
Pipedrive Create Contact like this:
Then get the ID from results of step one, and the title of the deal (whatever id like)
How do I set other fields in the deal/contact … like first and last name, email, etc etc from the form I have created?
there doesn’t seem to be much on the forum about it.
Cheers
https://zeroqode.com/plugin/pipedrive-plugin-for-bubble--1503655970768x869483716434460700
By the looks of things it’s a super limited plugin that pretty much hits it’s limit at what you’ve done there.
This is all it can do
Screen Shot 2022-04-21 at 12.12.55 pm
You might want to just look at integrating the API directly, it looks pretty straightforward from what I can see. If that’s mildly terrifying for you :rofl: and need help getting started on that book some time with me via my website.
Josh @ Support Dept
Helping no-code founders get unstuck fast :rocket:save hours, & ship faster with an expert :man_technologist: on-demand
yeah, no worries cheers… I felt that it seemed pretty limited - weirdly when you result of step 6 in this case you get to see all the things in the API you could potentially have on the record… and that make me sad
Api wise, I give anything ago … I am ok with the Wordpress API for custom stuff with Zapier… so it may be fun.
But yea if I get stuck Ill hit you up.
Cheers
Super easy fixes from a plugin perspective, you just need to map inputs in the workflow so they can pass to parameters into the API call.
Similarly then cloning that call and changing the API endpoint to like ‘update contact’ is achieved in minutes.
But I guess that’s free plugins for you. They get built for a narrow use-case for a client and then abandoned.
Josh @ Support Dept
Yea I guess so, shame… I guess I’ll have a play later see if I can work it out…
