Ziggeo input resize issues in repsonsive
I cant recreate this in the forum app easily because I dont have a Ziggeo token for it but I could always try if you need this to check out.
When I load the ziggeo video input on a static page and then in the preview when I resize the window, all is well.
When I change the properties of the page to responsive rendering and uncheck the static checkbox and try and resize the input element vanishes and only returns on a refresh.
I tried adding the input element in a group, tried to make that static, the element static, nothing works.
When you’re not resizing it is not an issue, but the problem is present from page load on a mobile device which is pretty annoying.
is this a bug?
A bug report would be better for this.
