Ziggeo plug in [original] problem
Hi there to all video folks!
I’m using Ziggeo plug in built by the Bubble team. And facing quite some issues
  1. Can’t record a video on Safari as it shows Adobe Flash error message
  2. On Chrome, the record button is not always working, less than 50% chance the button isn’t reacting at all.
The Ziggeo Support team says that the original plug-in is using V1. and currently they have V2.
Any plan to upgrade the plugin?
Or should I purchase one of the paid versions? Do you recommend @cneat083 @bubblify?
Hi @ohyoonkwn,
This is a typical use case for the Advanced Ziggeo Plugin, which is always compatible with Ziggeo’s latest stable API version (V2-r35 at this moment) so you can use the latest techniques like webrtc and lots of other features Ziggeo has implemented. It comes with many parameter options to enable/disable and configure your player and recorder elements easily.
Give it a try and let us know if you need help via a DM!
Good luck!
PS: Our one-time price offer expires on December 1st, just so you know…
