Thats really sad and pathetic. Very unethical. Whoever is behind that needs to be called out. ![]()
Noob question because believe it or not I have never had a need to bump any of my Bubble apps beyond Starter (shame shame I knowā¦but Iām cheap) even for my 5-6 digit revenue generating projects. I am also secretly a troll that does not like to collaborate.
So, the question is do I need to bump to Growth? Or will Bubble spank me (and charge me for Growth) for trying to cheap out by trying to add a collaborator while still in Starter. I donāt need to use Buildprint but I want to use Buildprint cause I like frontier projects.
You donāt need to upgrade to Growth, the Buildprint collaborator bypasses collaborator limits on your plan.
But Iād strongly recommend it, as itās important to have agents working on separate branches.
Thanks for the clarification. Iāll take it a step at a time.
Iāll eventually bump to Growth in the next few months as our business grows and then Iāll muck around with agents. Iām still too much of a control freak to let agents mess with my work, Bubble or not.
Sure, just use Buildprint in read only mode!
Please release editor mode to the rest of us!! I have a giant repetitive task that Iām dreading, but Buildprint could do it in a snap
So to use buildprint we do not need to add buildprint as a collaborator in our app editor?
You do, if you want it to make edits you need to give it edit rights (just like with any other collaborator editing your app)
You can give it as much permission as youād like, but if it has less access that inherently means some features wonāt be able to work
How does it bypass collaborator limits on the app plan then?
Itās an agency user essentially
thereās a different word to describe that and itās not cheap.
It seems that the BuildPrint Logs tab are shown only in UTC Z timezone. Thatās fine if youāre in the UK, but otherwise, thatās not the local timezone ![]()
Could you please allow changing the timezone, for viewing the logs?
Cheers
Only for 3 more weeksā¦
Happens a lot when someone does something that is successful.
Jealous people. Jealous agenciesā¦and maybe those who have a vendetta against Bubble and are on a one-person mission to spread false info.
They do it in any businessā¦leave bad reviews, etc. But the real people who appreciate what you do can see through it all.
Keep up the good work.
Youāre appreciated a lot more than the couple of losers trying to put you down
Working on Buildprint API so you can programatically kick off agents. Curious if people need anything in particular?
Right now, Iām implementing:
- start agent (with specific prompt/project/reasoning/model/permissions etc)
- get agent (get agent results / history)
- start code review between branches
- get code review between branches
This would allow you to, for example, have a daily automation which gives you details of changes on any branches, or have a support form automatically triage any issue with a Buildprint agent.
That covers all the basics and moreā¦
Are you all using Claude with Buildprint?
Iām using Antigravity IDE with the MCP and swapping between Gemini and Claude Sonnet
Recommend using https://buildprint.ai rather than MCP as MCP wonāt have editing support as we canāt gate permissions effectively / restrict branches etc
Public API
Buildprint public API now exists. Go wild and build things. Getting started | Buildprint | Docs
