Iāve just sent off a first round of invites to the Buildprint AI editing beta.
If youāre interested, please reply below (Iāll struggle to keep track of DMs). If your name / profile is obvious then Iāll be able to find your workspace and grant you access (though Iāll be doing it gradually just so I can deal with any issues as they arise )
I definitely want to try this out soon, but could you clarify if you have an option like this?
Iām assuming you personally have the ability to see anything thatās contained in our appās JSON after itās been filtered/extracted (or data if we enable access to data).
Weāre constrained by the Bubble collaborator permissions and additionally restrict it so it canāt access private API keys or plugin values. There are docs on the permissions and privacy options tho
@georgecollier My app has been in production for 6 years and Iām learning new things about it thanks to this, itās absolutely fantastic. Instantly a must-have for any bubble app. Would love beta access if available.
Gave the beta a test-run today and let it have a go at a couple of tasks - conclusion: absolutely blown away.
Task 1: I needed to duplicate a load of buttons and their respective workflows/actions to use them as new buttons on a newly built side-panel. To avoid workflow duplication I asked for it to make the button workflows into custom events instead, first, so they could be triggered from multiple other places without duplication. It did it. I manually checked the work - flawless
Task 2: this one iāve been putting off for MONTHS⦠147 workflows sat in āuncategorizedā folder. A real chore to manually move them into sensible folders. I asked BP to do it and gave it the desired folder naming convention⦠it moved them into my existing folders and created new folders where needed. 1 go. Flawless.
Canāt praise this thing enough. Genuinely exciting.
PSA: We now account for a significant amount of Bubble logs requests so are throttling requests whilst theyāre doing some planned backend work (that will improve logs for everyone, whether you use Buildprint or not). If you see log sync fall behind, thatās why.
Is there a way to lock BP down to a dedicated branch without having to include it in the prompt? I know it does save points but I think if it can be fenced-in to a specific branch, that would alleviate the current āopenclaw phobiaā.
I will add the ability to add your own system prompt, behaviour guidelines, style guidelines etc for each project too at some point. I just want to make the UX nice (so it autopopulates style guidelines based on app naming convention UI etc rather than you just typing it)
