Hi!
I want to put this code; current date/time - last_active :seconds > 5 in my constraint. So it will check when the user was active within the last 5 seconds. it works fine in the Only When thing, but not as a constraint.
please help!
Hi!
please help!
Screenshots required.
Alright! Here ya go!
In this situation, the User’s fields start the constraint. So try to switch up your expression to get the same result.
Example:
[MELDKAMER] last active > Current date/time + 5 seconds
Or something like that.
Sorry this might just be dumb math but i think i should work?
(It is a Do every 3 seconds, not Do every 5 seconds)
But it doesnt work…
