I think consistency is a priority over speed, when you see something works and then doesn’t, you know you cant rely on it.
For example i just created a “Do when condition is true” workflow which gets triggered “Only when” a specific list, filtered, count, is > 0, set as “Every time”.
The result is mixed, sometimes it works sometimes it doesn’t, which obviously is not your bug, only a server issue.
I think bubble should focus on consistency first, i can’t build something i can’t rely on.
