Can’t we view information with a certain condition/restriction like in SQL?
example:
VIEW name
WHERE job_id = ‘IT Admin’;
This is to display people from the DB that work only as IT Admins.
example:
VIEW name
This should be possible with filtered advanced option? I don’t know any way from the database except for typing in the search field.
You can also use a plugin that connects to the database.
Thank you for the response, I will try out your suggestions.
