Whenever I add a CSS class (through Attribute ID-field) to a ‘vertical scroll’ - repeating group, it stops loading new cells when scrolling. I can see the first 2 cells of the RG, but when I scroll down, no new cells are being loaded. I just added a simple css ‘height: 100vb !important;’ in order to adjust the RG’s height to the viewport. Can someone please help? It’s driving me crazy. Tried various workarounds, but whenever i add CSS, something somewhere breaks. :(((
Been trying and researching for 30 hours straight.
And 20 minutes after screaming for help in bubble forum i finally found the solution
Whenever CSS conflicts with bubble workflows, you just have to dynamically remove the class via {removeClass:} and put it back on after workflow with {addClass}. Simple as that! I won’t delete this thread. Maybe someone will find this helpful. Thank you for reading haha
Wow, you did really good. I also think someone will find this useful. I did not know this.
You should clarify that you are using the Classify plugin so others don’t get confused.
Can you please tell me step by step how to apply it? I don’t have CSS practice yet
