Help in Algolia Integration (with ZQ Plugin)
Hello,
I need help in integrating Algolia into my Bubble app. i am using the Zeroqode Algolia plugin for the connection to Algolia. I want to achieve a search and filter functionality for the users as they would find it on Amazon. However there are a few technical difficulties that I would need help with for that.
Does anyone have expertise regarding this topic?
Cheers, Lukas
Hi Lukas,
What you are wanting done is well within my area of expertise and I would be glad to help you out on this.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
Hello @lukasraymann02,
Thanks for reaching out.
Sure, thing. We would like to help you with the difficulties you encounter while using our plugin. Therefore, please provide as many details as possible. Any screenshots/additional explanations will be highly appreciated.
Hope to hear from you soon.
Best regards,
Zeroqode Support Team
Hey @lukasraymann02 :wave:
There is also a cheaper alternative to Algolia called TypeSense if you want to take a look
Here is a paid tutorial on how to connect it yourself using the API connector.
Just in case. :blush:
