You should try to change the header for Accept-encoding * instead and probably add an
Accept with value to application/json
(I think you should try just with the accept header first)
Thanks. if I could give you a kiss hahahaha I thank you from my heart. in case I need it, can I count on your help if it’s not bothersome?
You can always post on forum and if it’s not me, someone else will try to help you
Would you be able to give API doc url?
Likewise, you can settle on the decision from mailman to requestbin. Actually look at all headers and setting there and set exactly the same thing in Bubble.
What I speculate you are missing is most likely User-specialist
