Help Us Contribute to the Future of Bubble Mobile Plugins
Hi Matthew, you need to be part of the mobile beta. Reach out to bubble for more info.
Would this be possible?
Recording plugin is launched with these exact requirements in mind.
Definitely possible, but I don’t see a straightforward way of creating a general plugin out of this. We can create a custom one for yourself, in that case send me a DM.
We built the audio recorder, when you start recording, you can set a time limit.
Link: Audio Recorder Bubble Mobile Plugin | Bubble
Hey @nocodeventure ,
I’m trying to use the Audio Player (Bubble Mobile).
How can I set a single url rather than a list?
How to set a value for the volume ?
Thx
My bad, a new update is pushed out @thiv to allow changing the sound volume without using the custom action and also support to add a single audio file (Version 1.6.0
Lottie player now supports .lottie files @thiv
could you create a .ics file generator? e.g for apple calendar event generation.
this web app plugin exists, but seemingly none for mobile Ez ICS File Generator (Calendar) Plugin | Bubble
I’m sure many need the option to enforce landscape or portrait, either by blocking the rotation, or by showing a full-screen modal asking to rotate back.
Hi @nocodeventure ,
Can you avoid audio stopping when volume is set to 0 and when audio is muted.
Thx
Hi Thiv,
This isn’t really a support thread, so feel free to DM me instead. I had a quick look at both of our audio players, and it seems they keep playing even when muted or set to 0 volume. Happy to help check it out further, just send me a few more details.
