Help with gpt workflow calls
Hello developers, please i want to ask and i will really appreciate your feed back.
What is the best method in a Bubble Workflow to construct a complex prompt from a series of user inputs to use in the ChatGPT API call? Trying to construct the prompt in the field for the body of the API call is obviously extremely unwieldy.
I guess the larger context for this question is in Bubble how does one construct a complex, lengthy string from a combination of pre-set text and user inputs? Doing it in an actual Bubble editor input field is maddening and could lead one to begin to bash one’s head against one’s wall…
Oluwatobi
What API calls have you set and what fields do you have?
If you attach some screenshots it would be good
