I’ve decided I want to use a messaging SDK called Applozic instead of building it in Bubble because of performance and scale issues. The documentation looks fairly simple, but I’m missing something. Has anyone used Applozic or another messaging SDK before for Bubble?
I just quickly passed through the documentation. My conclusion would be to create a Plugin (a high challenge task if your notions in javascript are like mine). The authentication process must also be incorporated. On the other hand, I estimate that the job of creating this plugin is about ten hours. You can ask several developers of plugins an estimated one. Here is a series of ‘screenshot’ to guide you.
