Help with usernames
hello so I’m new to bubble and can’t figure out how to do a user name currently it says this Screenshot 2019-12-24 at 10.42.41 PM
if you could help that would be great
I think that you have set the username field type to number instead of text.
no because ive even deleted and readded it as text to make sure
Well then the input you’ve called “username” is validating to the wrong type. Change that so it just accepts free text.
