Hide Element On Click Anywhere
Hey guys,
I’m trying to add a normal UX interaction practice to my web app.
When my account menu is opened, I want to be able to click anywhere other than the account menu div and close this element.
Why are you showing me code?
thats how
What should I do with the code?
https://puu.sh/C6Oiw.png
I want a way to create it without code. That’s why I’m using Bubble.
https://puu.sh/C6Oqa.png
Hi there,
You can use a Group Focus element to accomplish this, simply replace that menu group you have there with a Group Focus.
You can also accomplish this smoothly with “Replace by another element”
Awesome!
I don’t understand how to use the element. It’s locked into the top left corner of my screen.
You have to anchor to another element, that’s a requirement. Then you can use the vertical and horizontal offsets to adjust the group
You’re a BEAST BRO.
Thanks so much man.
