If you’re looking to buy or sell just about anything under the sun, Craigslist is a good place to start your search.
This is a companion discussion topic for the original entry at https://bubble.io/blog/build-craigslist-no-code-template/
Great tutorial. One big question I have, and I’ve not seen addressed by many of these tutorials, is that in reality, we need a way for a registered user who creates and posts an ad, to be able to log in and potentially EDIT their ad if they need to make changes. So we need a system that allows a user to log in, then view only their listings that they created, make edits and then save them. If someone could expand on how this could be done, that would be very helpful.
Useless! Need updates nothing is the same as is showing on your screenshots and skip so many steps
You will easy to create a craigslist clone. Only $499usd.
https://mindleef.com/craigslist-clone/
