If your destination is an address, Uber is one of the leading applications to get you there on time. If you’re on a journey to build your own no-code version of Uber, however, Bubble is the only application you’ll need.
This is a companion discussion topic for the original entry at https://bubble.io/blog/build-uber-clone-no-code/
Hello, am new to bubble! How can I build an app where payments are made in my local currency, Uganda Shillings? Is there a way to use mobile money as a payment method? Will be delighted to hear from you.
Kind regards,
Jimmy
Hi, did you ever experience issues with the “Google Maps Extended” plugin?
I have no problem setting it up in my application, sometimes it just doesn’t work and errors out on page load.
Also, how did you put it on mobile platform ? Is it a simple wrapper ?
