Dears,
Appreciate your help
How can I reverse merging text order from left to right? The result should be “Inactive ====== Active” instead of “Active ====== Inactive”
Regards
Dears,
Regards
Just reverse the dynamic expressions in the text element
thank you for reply
This was an example, it is a log list.
I think I found the solution
Add HTML element
Regards
