I need a dynamic Connection string
Helo!
Need help!
I need to use the “SQL DataBase Connector” plugin by passing a dynamic Connection string.
How do I do this, or is there any other plugin with this possibility?
Reason: I use the same data bank on several clients, however, the server’s IP address varies from one client to another, so I need to define the IP at the time of the call and not in a fixed way
Did you find a solution to this?
I’m trying to switch which connection to use for all my sql calls based on bubble version/branch ‘development’ vs ‘live’
In our pro plugin there is a place in the plugin settings to specify the dev connection string and the live connection string respectively. SQL Database Connector Pro Plugin | Bubble
