I need Help regarding calculated fields
Hi I’m new here and i need help regarding calculated fields in bubble.
I’ve created 3 input fields in my form Cash, Bank and Total. I just want if any one fills in cash and bank input fields the amount added and show in total field and after i click submit it should also enter in database. Any help will be appreciated.
Hi there and welcome to Bubble :slight_smile:
Why is the Total an input field? Do they need to be able to update it?
If not then you can have a text field with a formula of Cash + Bank inputs
Otherwise you can use the “default” on the input.
Initial value in Total : Input Bank’s value + Input Cash’s value
Thanks for the reply but i don’t know how to use formula can you please tell me about it a little?
Thanks ill try that.
