I need help with a few things
I used a template to start a project and im wondering how I would change this to what I want.
That is my projects tab when i have it open. I want to change what it says on the tab.
Go to the page editor - and change the page title.
Where exactly do i go for that i cant find it?
Double click on the outer portion of your page, or right click and select edit. Then change the title:
Fixed it thank you.
Another question, how would i change this immage?
This updates based on your image that is on that index page. May take a while for you to see the changes.
