🎉 Introducing AutoBubble — Build and ship Bubble plugins with AI
Hey everyone :waving_hand:
I’ve been building on Bubble for a while, and one thing always slowed me down: plugins.
Creating one from scratch? Hours of trial and error. Editing an existing one? You’re either deep in someone else’s undocumented code or copying context into ChatGPT and praying the answer fits your app.
That stops today.
AutoBubble is an external platform where you can generate, edit, and ship Bubble plugins with AI — or tweak them manually if you prefer. When you’re ready, you invite AutoBubble as an editor on your plugin and push the changes directly to Bubble with one click.
No more context switching. No more generic answers. Just your plugin, built the way you need it.
Plugins are also one of the best ways to inject custom code into Bubble — extending your app beyond what the platform natively supports. But doing that today means either knowing a lot of code or spending hours figuring it out. AutoBubble changes that: get the custom functionality you need, fast, without deep technical knowledge.
The bigger mission? Democratize plugin development on Bubble. Today it’s a skill reserved for a few. With AutoBubble, anyone — regardless of technical background — should be able to build exactly the plugin their app needs.
What you can do with it today
  • Generate a plugin from scratch — describe what you need, AutoBubble builds it
  • Edit existing plugins with AI — import your plugin easily, ask for changes, get results that actually make sense
  • Edit manually with a better editor — AutoBubble is a supercharged Bubble plugin editor. Everything you can do in Bubble’s native editor, but faster, cleaner, and with AI right beside you when you need it
  • Push directly to Bubble — invite AutoBubble as editor and ship with one button
Generate an entire plugin in less than 10 minutes.
Beta — 5 spots only
AutoBubble is in beta, and I’m personally inviting 5 builders to be the first to use it.
Want in? Reply to this thread and tell me why you should be one of the 5.
What are you building? What plugin problem keeps slowing you down? I’ll read every reply and reach out to the selected builders.
Prefer to keep it private? Send me a forum DM instead.
Who this is for
Honestly? Everyone building on Bubble.
Whether you’re an agency, a solo builder, a developer selling plugins, or someone who just started and has no idea how plugins work — AutoBubble is being built for you.
Plugin development on Bubble shouldn’t require years of experience. That’s the whole point.
Make updates in just 1 minute
What’s next
  • Constant AI improvements — the more it’s used, the smarter it gets
  • Public beta — private beta is just the start; opening up broadly soon
  • Bubble Mobile support — create and edit plugins for Bubble’s mobile apps, not just web
https://autobubble.dev
Questions? I’ll be in the thread.
That sounds great, @carlovsk.edits , good job man! :brazil:
Looks fantastic. I’d love to be beta tester but do not have time right now so will happily watch as others help you perfect it :sun_with_face: good luck - really looks like a great product. :+1:t2:
Nice!
A user reviewed one of my plugins and asked if it could work with RichText inputs as well.
So I asked AutoBubble to implement it, and it was done in 67 seconds.
Amazing work @carlovsk.edits!!!
I’d loved to give it a try!
I’m building some plugins and I’m going through this point you mentioned, I’d love to test it.
I’m helping Carlos test Auto Bubble and I’ll talk about two plugins I created.
I have a lot of experience with Bubble, but I’d never made a plugin before.
The first one allowed the user to paste an image copied to the clipboard using the shortcut ctrl+V or cmd+V. This one was created with just one prompt and worked perfectly right away.
The second was a much more complex case of something I needed for a project and hadn’t found a way to do.
I needed an input that would perform mathematical calculations by mixing numbers typed by the user’s keyboard, mathematical operators, and items from my database. I’m still making some adjustments because the plugin is very specific to what I need, but the result so far is great and the plugin already works perfectly (images below).
I think this tool has a lot of potential, precisely to give more customization power to regular Bubble users.
Great work, @carlovsk.edits
Hey, @carlovsk.edits the idea undoubtedly is interesting. I tried signing up, but it says “Sign up is currently limited to invited emails.“
I’m going to guess that’s because it’s invite only :slight_smile:
That’s right @georgecollier :grin:
I’ve already found 3 beta testers; now I just need two more :slight_smile:
It looks very interesting !
I don’t have a lot of time to help you on this but will definitely try to use it at one point.
I have a drag and drop plugin idea
Wow! I hope to join you! I want to make some kind of auto data-return plugin(?), which returns what I needed (the calculated data when I choose different types and fields.).
e.g. member’s rank, education which is neended and done etc. it makes me work hard to set workflow in order to calculate it… It would be great if we could use dynamic expression more fast and easily by using plugin.
Quick update — the 5 beta spots are now filled. Thank you all for the interest, the replies, and the kind words. Really means a lot.
@AdrienD drag and drop is a great idea — noted for when we open up more broadly.
@hobum91 that auto data-return use case is exactly the kind of thing AutoBubble is built for — excited to see you try it.
Based on beta feedback these past days, I’ve already shipped three new features:
Save Points
Before making a change, you can create a save point to preserve the current state of your plugin. AutoBubble also creates one automatically every time you push to Bubble — so you always have a clean rollback.
Sync with Bubble
If you made edits directly in Bubble and want to bring those changes back into AutoBubble, you can now sync with one click — no need to push, no risk of overwriting your work.
Bring Your Own Anthropic API Key
You can now connect your own Anthropic API key in settings and use your own credits instead of AutoBubble’s. Your key is stored fully encrypted — no need to worry about that.
Smarter AI
Improved the context the AI receives about your plugin — it now understands your code better, which means more accurate suggestions and fewer back-and-forth corrections.
Private beta is closed for now, but public beta is coming soon — everyone will be able to access AutoBubble.
Stay tuned :raising_hands:
:tada: Public beta is now live!
Thank you all for the incredible support since launch — the response blew me away.
AutoBubble is now open to everyone. No invite needed.
If you’ve ever wanted to build a Bubble plugin but didn’t know where to start — this is your moment. Describe what you need, and AutoBubble builds it. No deep technical knowledge required.
And if you already build plugins? You’re going to move a lot faster.
:backhand_index_pointing_right: autobubble.dev
Sign up, build your first plugin, and let me know how it goes. I’ll be right here in the thread. :rocket:
Good job!
Also, a good idea.
I have a plugin in mind, and I’ll check this out :grinning_face:
This service is very useful! But connecting Claude and adding credits via autobubble does not work either. I hope this solved soon because Autobubble is really good at making plugin!
Thanks for flagging this! Just deployed a fix for both the Claude connection and the credits flow, should be working now. Let me know if you still see any issue.
Really glad to hear you’re enjoying AutoBubble for plugin building! Would love to hear what plugins you’re working on if you’d like to share. :rocket:
I’m currently working on AutoBubble so you’ll be able to build plugins for Bubble Mobile too, not just web. Should be available soon.
On top of that, I’m taking some time to build a Bubble app that brings together all the free plugins I’m creating, and then I’ll post each one of them here on the forum. The goal is to keep helping the community with great free plugins, and at the same time show how AutoBubble is evolving and getting better at delivering higher-quality plugins.
I can’t wait to see other folks here posting their own plugins too, and mentioning at the end that AutoBubble helped them build that one plugin that solves a real problem in one app, or in many apps. I’m genuinely excited about that.
Have a great weekend, everyone. I’ll be back with more updates soon, haha.
