This video is closer to the assumption than the glide template. Is it possible to make this bubble clone?Inventory Management System in PHP with Source Code
Yeap!
Thanks!Do you have this template?Or can you make it?
You can make it from scratch or look for similar templates on the Bubble Marketplace.
Agree with @johnny here!
Most Bubblers should be able to do it.
Take the Bubble plunge @410thirteen you can build it as well
I searched for it, but I couldn’t find anything similar. If not, we will not consult.
