Hello I am trying to add a Vapi code snippet to my bubble app so that I can access its assistant features.
Here is the code snippet on the Vapi website that I am trying to add: Web Snippet - Vapi
I am pasting the code snippet from step 1 with my public api key and personal assistant ID.
I am watching this youtube tutorial: https://www.youtube.com/watch?v=XOVt1qHmrlg&t=391s&ab_channel=JannisMoore|AIAutomation
You obviously don’t have to watch the whole entire tutorial but if you watch from minute mark 4:12 to 5:15 you will see how the guy is adding the code snippet to his website by copying and pasting it. I thought I could accomplish the same thing on bubble by adding the code snippet to the page HTML header.
However after adding my public API key and assistant ID to the HTML header the page is still blank and I do not have the live chat feature from Vapi. Do you know what I am doing wrong that is not allowing this to work? Here are screenshots on where I added the code snippet
In the documentation, step 3 is to add button config.
replace
const buttonConfig = {};
by
position: "bottom-right", // "bottom" | "top" | "left" | "right" | "top-right" | "top-left" | "bottom-left" | "bottom-right"
offset: "40px", // decide how far the button should be from the edge
width: "50px", // min-width of the button
height: "50px", // height of the button
idle: { // button state when the call is not active.
color: `rgb(93, 254, 202)`,
type: "pill", // or "round"
title: "Have a quick question?", // only required in case of Pill
subtitle: "Talk with our AI assistant", // only required in case of pill
icon: `https://unpkg.com/lucide-static@0.321.0/icons/phone.svg`,
loading: { // button state when the call is connecting
color: `rgb(93, 124, 202)`,
title: "Connecting...", // only required in case of Pill
subtitle: "Please wait", // only required in case of pill
icon: `https://unpkg.com/lucide-static@0.321.0/icons/loader-2.svg`,
active: { // button state when the call is in progress or active.
color: `rgb(255, 0, 0)`,
title: "Call is in progress...", // only required in case of Pill
subtitle: "End the call.", // only required in case of pill
icon: `https://unpkg.com/lucide-static@0.321.0/icons/phone-off.svg`,
