Looking for freelance for project
Hi there,
I’m building an MVP and need help integrating Mapbox (or other free/cheap map solution) with Bubble.
Help?
Hey :wave:,
Have you tried this plugin: https://bubble.io/plugin/leafy-maps-1562697922620x934462587697889300
If you still need help you can book a session with me and I can help you more. I would be happy to help. :slight_smile:
@j805 www.NoCodeMinute.com
Hope that helps! :blush:
Thanks @J805 I’ve been trying to use the plugin and perhaps my problem is setting up the Mapbox itself rather than the plugin…
Will write to you! Thanks :slight_smile:
Sounds good! :blush:
