Need help building a tool (resume builder) for my app
I’m trying to build a tool where my users can select from a few different resume templates and then input their information/ skills/ experience into the template. Any idea of where to start, i’m new to this so any help to get the ball rolling would be much appreciated!
Doing this for a client.
If you were to do it entirely in Bubble it might be a bit tricky to make it pretty enough but it’s certainly possible. I’d start by:
  1. Recreate the JSON Resume structure in your database
  2. Allow users to add all of the relevant information for each data type
  3. Allow users to order it all (or auto-order by date for relevant areas)
  4. Display on a page using repeating groups and conditional formatting
  5. Allow export to PDF using a plugin
Step 4 is hard because you essentially need a new page for each resume style template.
Hi George I’m looking for a Bubble developer/agency to create an app very similar to what you are describing. Can I ask, why the API call to your personal service, instead of using a plugin to render the PDF from the various Bubble DB fields?
Also, in Step 4 you describe as complex, if you allowed users just one template, that would be much easier, no?
thanks
Because my service takes a JSON formatted resume and template ID and returns the generated PDF. It handles showing/hiding necessary sections. It means adding new templates is a case of downloading an extra library rather than manually doing it in Bubble :slight_smile:
Hey @hibubble
Still need help? Feel free to schedule a meeting with us!
empowered.guru
