Hi, so I am using the Google Maps plugin, and essentially, I would like to show all jobs on the map view. I have set filters to show jobs based on their date, job types, etc. Unfortunately, when I load the page, it does not show any jobs, but as soon as I reselect the date, it shows the jobs correctly. Also, if I remove the date filter, it loads correctly, so I think I am doing something wrong with the date filter. Any help would be appreciated. Attached are screenshots of my setup and a video showing the issue.
What is the setting for end date picker?
If you also use current date and time… There’s probably nothing that fall in between start and end date picker because both will have the same value. But when you select the date in start picker, it may set it to selected date 00h00m00s
Just checked your video and pretty sure the problem is time. Change start date for current date:rounded down to day
Hey thanks so much!! That was the issue. I appreciate your help greatly, I was stuck on this for hours!!! All the best to you.
