Need help in calling backend workflows
I have an API endpoint which receives data from shopify. This contains information about return items for a particular order.
I can have multiple line-items under each order. I need to update the status of these line items based on the data I get from shopify return webhooks. The response looks like below:
    "return_line_items": [
            "id": 1234567890,
            "admin_graphql_api_id": "gid://shopify/ReturnLineItem/1234567890",
            "quantity": 1,
            "return_reason": "size_too_large",
            "return_reason_note": "",
            "customer_note": null,
            "fulfillment_line_item": {
                "id": 1234567890,
                "admin_graphql_api_id": "gid://shopify/FulfillmentLineItem/1234567890",
                "line_item": {
                    "id": 1234567890,
                    "admin_graphql_api_id": "gid://shopify/LineItem/1234567890"
            "unit_price": null,
            "type": "ReturnLineItem",
            "restocking_fee": null
            "id": 1234567890,
            "quantity": 1,
                "id": 1234567890,
                "line_item": {
                    "id": 1234567890,
            "unit_price": null,
There are 2 items in return_line_items array. I have a table which has return_data which also has fulfillment_line_item.id (I can use this to identify the record). So when I receive this endpoint, I need to update all the records in return_data table with the new return status. How can I do this?
Can you share your backend workflow?
Also is this a webhook or a normal public api workflow thats able to recieve data? In this case you would need to set every key value pair in the api workflow
