Need Help Setting Up UI-Avatars Plugin in Bubble.io
Hi, I recently installed the “UI-Avatars” plugin in my Bubble.io app, and I’m having trouble figuring out how to set it up properly. I see that it uses a ‘Data call’ (Ui-Avatar - Get Ui-Avatar), but I’m not sure how to configure it to generate user avatars based on initials or names dynamically.
Could someone explain the steps to set up the plugin and display the avatars on my app pages? Any help with API call settings or using the plugin with dynamic data would be appreciated!
Thanks in advance!
Why not build your own using truncate operator in the user First/Last name?
