Need help with Bullhorn ATS API
Hey everyone! I’m looking for someone who can help me integrate the Bullhorn ATS API into the API Connector so I can make calls between my app and the Bullhorn ATS.
Here is more information on Bullhorn: Bullhorn REST API
If you’re experienced with using OAuth2 and want to help take on this integration, let me know!
Hi Justin,
If you are still looking out for someone, I would be interested as I have in the past worked on some complex API integrations in the past.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes and Have a great day ahead,
Andrew
Yes, I can help you integrate the API. I have already done in the past.
For Bullhorn ATS users looking for integration, I’ve made a plugin for the API integration. https://bullhorn-ats.bubbleapps.io/version-test
I’m very interested in Oracle Taleo integration also.
Youtube channel with 10+ setup and best practice videos - Bullhorn ATS Bubble.io API Plugin - YouTube
We may be a bit late to the party, but we have built a bubble plugin for exactly this use case. It allows you to connect to over 25 ATSs without writing a single line of code.
Let me know what you think :slight_smile:
